Zum Hauptinhalt wechseln
DJI Mavic Pro Top Case Removal
Englisch
Deutsch
Schritt 6
DJI Mavic Pro Top Case Removal, Pry up Rear Case: Schritt 0, Bild 1 von 3 DJI Mavic Pro Top Case Removal, Pry up Rear Case: Schritt 0, Bild 2 von 3 DJI Mavic Pro Top Case Removal, Pry up Rear Case: Schritt 0, Bild 3 von 3
Pry up Rear Case
  • First, turn the drone over, so it is right side up, and facing away from you. Now, use a metal spudger to pry open the rear end of the case. Be careful not to pull too far up, as there is still a cable which is connecting the two pieces.
  • Slide the spudger down the length of each side, undoing all the clips along the way, stop 1-2 cm before the ending of the battery cradle.
Hier Übersetzung einfügen
