Einleitung
A detailed look at changing the oil and filter, applies to any normal/older car with a spin-on filter and no electronic requirements
Was du brauchst
Collect the tools you'll need
Drain bolt wrench, drain-pan, jack, jack-stands, rags, filter-pliers, cardboard, funnel, gloves
For Subaru specifically, I'll be using a black Tokyo Roki LFS706 factory filter, sold by a Subaru as part # 15208AA100 with a new crush washer
Jack up the front of the car from the centre jack point if you have a hydraulic jack
Put jack-stands under pinch welds before gently lowering the car onto them
Check the stability of the stands before getting under the vehicle
Check your drain pan is empty and clean it out as required
Raise the hood/bonnet and open the filler cap to assist draining
Place the drain pan under the car
Climb under the car using your cardboard or a creeper
Remove the drain bolt slowly, adjusting the catch pan as it starts to flow to avoid spillage
Wait for the oil to flow from the engine
Clean the bolt
Remove the old crush washer if you have a new one
Fit the new crush washer onto the bolt
Clean the bolt mating flange on the cars oil pan
Put the bolt back into the engine and tighten to the suggested spec
Carefully adjust the now-full catch pan under the oil filter
Remove the old oil filter, using pliers or a wrench if required
I like large oil filter pliers, as they can be used also for brake jobs
The filter will be full of oil so place on your drain pan or carefully upright if your pan has no place for it
After the car mounting flange stops dripping a lot, prepare the new filter with a smear of oil on its gasket
Wipe down the mounting flange on the engine, and screw on the new filter by hand, 3/4 of a turn past when it touches the gasket
Carefully slide the now-full catch pan from under the car
Lift the car slightly and pull away the jack stands
Carefully lower the car to the ground
Push the front of the car down a few times to reset the suspension
If your drain pan has gradations you can guess approximately how much oil to put in
Or if your manual has a listing
My car takes AROUND 4.5 litres
Using a funnel, pour in 3.5 litres or so
Check the dipstick with your rag
Fill until near top of range on dipstick
Re-check there are no loose tools or rags in the engine bay, and start the engine for 10 to 20 seconds
After running the car for a few seconds, turn it off
Check the level again
The oil filter should be full now, so the level might be lower
Top up as required
Check under the car for leaks
If you used all your oil you should be able to use the empty bottle to put the used oil in
Funnel and lots of patience to transfer the oil from the catch pan to the empty bottle
You can drop off the old oil at car part places or some mechanics
Run the car around the block or so to get a temperature cycle and recheck level and leaks
DONE
Remember to check for leaks
