Einleitung
Use this guide to replace the driver side airbag in your BMW E36. This procedure was done on a US 1997 M3 with the four spoke steering wheel.
Was du brauchst
Remove the two screws securing the upper edge of the knee bolster.
Pull the upper edge down to give access to the underside of the steering wheel.
Remove the lower steering column trim mounting screw.
Remove the lower steering column trim.
Completely loosen the two T30 Torx screws behind the steering wheel while supporting the airbag unit from the front.
Lift the airbag unit up and away from the steering wheel.
Disconnect the orange harness connector from the rear of the airbag unit.
The airbag should now be free to be removed.
