Zum Hauptinhalt wechseln
1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement
Was du brauchst
Einführungsvideo
  1. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement, 3.4L Timing Belt/ Water Pump: Schritt 1, Bild 1 von 1
  2. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 2, Bild 1 von 1
  3. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 3, Bild 1 von 1
  4. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 4, Bild 1 von 3 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 4, Bild 2 von 3 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 4, Bild 3 von 3
  5. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 5, Bild 1 von 1
    • Loosen up the idler pulley by getting underneath the car and removing the 12mm bolt at the bottom of the idler pulley .
  6. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 6, Bild 1 von 1
  7. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 7, Bild 1 von 1
  8. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 8, Bild 1 von 1
  9. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 9, Bild 1 von 1
  10. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 10, Bild 1 von 1
    • Remove the nut that holds the pulley in place, which should be torqued down to 250 lbs .
  11. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 11, Bild 1 von 1
    • Using a 19mm wrench and a pipe, remove the nut and then remove the pulley .
  12. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 12, Bild 1 von 1
  13. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 13, Bild 1 von 1
  14. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 14, Bild 1 von 1
  15. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 15, Bild 1 von 1
  16. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 16, Bild 1 von 1
    • Line up the notches on the camshafts to set the timing before removing the belt .
  17. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 17, Bild 1 von 1
  18. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 18, Bild 1 von 1
    • Line up the camshafts by rotating the big pulley until the notches line up .
  19. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 19, Bild 1 von 1
  20. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 20, Bild 1 von 1
  21. 1995-2002 Toyota 4Runner 3.4L Timing Belt/ Water Pump Replacement: Schritt 21, Bild 1 von 1
Abschluss
Additional Information
- When lining up the camshafts, make sure to align the notches with the backplate, as well as the small arrow and dot on the bottom
- It is important to get all the old gasket off to prevent leaks.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
eCuration
376.693 Reputation
234 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.299 Anleitungen geschrieben
Ein Kommentar
Thank you so much for the video! As for ordering the parts for this repair i will go ahead and save a lot of trouble for those of you who may not already know when asked about weather you need the water pump that comes WITH ot WITHOUT the ENGINE oil cooler stem, I own a 1999 Toyota Tacoma Four-Wheel Drive V6 3.4L 5-Speed Manual Transmission
NikkiAutumn - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 16
Letzte 7 Tage: 111
Letzte 30 Tage: 445
Insgesamt: 61,282
