Zum Hauptinhalt wechseln
2003-2007 Honda Accord Keilriemenwechsel
Was du brauchst
Videoanleitungen
Abschluss
Um dein Gerät wieder zusammenzusetzen, befolge die Anleitung in umgekehrter Reihenfolge.
3 weitere Personen haben diese Anleitung absolviert.
en de
100%
Hier starten ›
eCuration
446.646 Reputation
239 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.468 Anleitungen geschrieben
3 Kommentare
CONTAINS NO INSTRUCTIONS! Directs you to YouTube to watch his videos. Should be removed.
Mike McAvoy - Antwort
This is a video embedded guide and can be watched here on iFixit or on YouTube.
Blake Klein -
Just did this replacement last night. Bought the belt from O'Reilly and rented the serpentine belt toolset. It didn't come with a 14 mm socket, but I was able to borrow one they had. Fairly easy to remove the belt, but putting it on, especially in the dark, was nontrivial. I recommend doing in the daylight.
Be sure that the tensioner springs pushes back while you're starting; it may need to be replaced too.
I had to really reach my arm all the way down to get the new belt on, and then be creative to get it around all the right pieces. Perhaps a longer socket would have helped for being able to push the tensioner back and still have space to work with the belt.
Water Ski - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 17
Letzte 7 Tage: 199
Letzte 30 Tage: 727
Insgesamt: 92,050
