Zum Hauptinhalt wechseln
2004 Toyota Sienna Sliding Door Motor Replacement
Was du brauchst
Einführungsvideo
  1. 2004 Toyota Sienna Sliding Door Motor Replacement, Sliding Door Motor: Schritt 1, Bild 1 von 1
    • First, test both sliding doors to identify the problem with the driver's side door
    • source.
  2. 2004 Toyota Sienna Sliding Door Motor Replacement: Schritt 2, Bild 1 von 1
    • Remove the second-row seat to access the door panel
    • source.
  3. 2004 Toyota Sienna Sliding Door Motor Replacement: Schritt 3, Bild 1 von 1
    • Remove the two Phillips screws holding the door panel in place
    • source.
  4. 2004 Toyota Sienna Sliding Door Motor Replacement: Schritt 4, Bild 1 von 1
    • Carefully remove the door panel by lifting it out and disconnect the power window
    • source.
  5. 2004 Toyota Sienna Sliding Door Motor Replacement: Schritt 5, Bild 1 von 1
    • Close the door and observe the actuator motor on the working passenger side door for comparison
    • source.
  6. 2004 Toyota Sienna Sliding Door Motor Replacement: Schritt 6, Bild 1 von 1
    • On the driver's side door, test the voltage to confirm it's an issue with the actuator motor and not an electrical problem
    • source.
  7. 2004 Toyota Sienna Sliding Door Motor Replacement: Schritt 7, Bild 1 von 1
    • Order a replacement actuator motor (Part #s in the video) and wait for its arrival
    • source.
  8. 2004 Toyota Sienna Sliding Door Motor Replacement: Schritt 8, Bild 1 von 1
    • Remove the window regulator by lowering the window and accessing the bolts through the portholes
    • source.
  9. 2004 Toyota Sienna Sliding Door Motor Replacement: Schritt 9, Bild 1 von 1
    • Remove the actuator motor by grinding off the stripped Phillips screws with a Dremel tool or using vice grips
    • source.
  10. 2004 Toyota Sienna Sliding Door Motor Replacement: Schritt 10, Bild 1 von 1
    • Replace the actuator motor with the new part, using socket screws from wall sockets or light switches if necessary
    • source.
  11. 2004 Toyota Sienna Sliding Door Motor Replacement: Schritt 11, Bild 1 von 1
    • Reassemble the window regulator and test the window function
    • source.
  12. 2004 Toyota Sienna Sliding Door Motor Replacement: Schritt 12, Bild 1 von 1
    • Test the sliding door in manual mode and then in power mode
    • source.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
eCuration
376.693 Reputation
234 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.147 Anleitungen geschrieben
Ein Kommentar
Great instructions! I was able to fix sliding door.
However, the window doesn’t scroll up all the way and it wiggles if you pull on it.
What did did I do wrong? Any suggestions are appreciated.
Nara Lim - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 27
Insgesamt: 2,196
