Einleitung
If your truck doesn’t start up with the same gusto as before and you’re constantly having to give it a jump, it might be time to replace the battery. Luckily, changing out the battery is one of the easiest maintenance tasks you can perform on your Silverado.
Ersatzteile
The hood release handle is located on the driver's side to the left of the emergency brake pedal.
Pull on the hood release handle to pop the hood.
To open the hood, reach into the gap at the front of the truck and feel for the latch. Push it to the left to release it and lift up on the hood.
The battery is located in the back left corner of the engine bay, partially covered by an engine bay brace.
Remove the four bolts holding the engine bay brace to the body of the truck with a 13mm socket and socket wrench. Remove the brace and set it off to the side.
Locate the battery hold down, which is a small block held down on the right side of the battery compartment.
Use at least a 6" socket wrench extension to reach the 13mm bolt and loosen it up.
Once it's completely loosened, reach down and pull out the bolt and the battery hold down block.
Locate the red positive cable and the black negative cable, both of which need to be removed using a 10mm socket.
Loosen the 10mm bolt on the black negative terminal just enough so that you can lift it up and remove the cable.
Push the cable back and out of the way. A simple trick is to rest it on one of the engine bay braces to keep it from springing back.
Flip up the terminal cover on the red positive terminal and loosen the 10mm bolt.
Lift up on the cable and move it out of the way. Resting it on the coolant reservoir keeps it from springing back.
The battery may have carrying handles that you can flip up if they're not already.
Grab onto the handles with both hands and slowly lift the battery out of the battery compartment.
Follow these instructions in reverse order to install the new battery and reassemble everything. MAKE SURE to connect the black negative cable last to prevent shorting the battery to ground.
4 weitere Nutzer haben diese Anleitung absolviert.
