Einleitung
The engine air filter should be replaced once every two years.
Follow this video tutorial by YouTuber NutzAboutBolts to complete the replacement yourself.
Was du brauchst
Einführungsvideo
Carefully slide the air box out, making sure to avoid damaging the connected components
Inspect the old filter and determine if it needs replacement based on its condition and mileage
If the filter needs to be replaced, insert the new engine air filter (part number 17801-37021) into the air box
Reinstall the air box by carefully sliding it back into position and securing it with the clips
Remember to always check your engine air filter when replacing it, and be mindful of your driving environment, as some areas may be dirtier or dustier than others
Regularly replacing your engine air filter can help maintain optimal engine performance and efficiency.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
What is above the air filter? It looks like another filter that has been glued to the housing right above the replaceable filter.ty
