Einleitung
The clockspring is a plastic circuit in a vehicle's steering mechanism that connects the steering column to the steering wheel without breaking the electrical connection when it rotates.
When the clockspring fails, the steering wheel loses its electrical connection, and its buttons, horn, and other features stop working. This guide will help you replace the clockspring and restore the functionality of the steering wheel buttons in a 2014 Ford F150 Lariat pickup truck.
Before beginning this procedure, place your vehicle in park, engage the parking brake, and power off the ignition.
Was du brauchst
Disconnect the cables to your vehicle battery using a socket wrench and 10mm socket.
Find the two holes on the sides of the steering wheel.
Insert a small screwdriver into the hole on one side and push to release the clip holding the airbag in place.
Repeat on the opposite side to release the airbag.
Use a small flathead screwdriver to pop up the tabs on the airbag connector wires and disconnect them.
Disconnect the horn wire.
Carefully remove the airbag and set aside.
Use a socket wrench and 7mm socket to remove the three screws underneath the steering column that hold the two parts of the steering column covers in place.
Separate the steering column covers and push them aside to access the clockspring.
Unscrew the broken clockspring using a T10 Torx screwdriver to remove the four screws holding it in place.
Install the new clockspring using a T10 Torx screwdriver.
Replace the four screws and tighten them.
Remove the clockspring lock tab to release the new clockspring mechanism.
Move the steering column covers back into place and replace the three screws underneath using a socket wrench and 7mm socket.
Feed the two airbag wires through the back of the steering wheel to begin replacing it.
Replace the steering wheel bolt and tighten it with a socket wrench and 24mm socket.
Reconnect the horn wires and the airbag wires.
Push down the tabs on the airbag wire connectors to make sure the connection is good.
Check for a successful installation by cranking the vehicle to see the Engine OK light indicator on the dashboard.
Check that the steering wheel control buttons work.
