Zum Hauptinhalt wechseln
ACER Aspire 7750G-6645 Fan Replacement
Was du brauchst
  1. ACER Aspire 7750G-6645 Fan Replacement, Keyboard: Schritt 1, Bild 1 von 2 ACER Aspire 7750G-6645 Fan Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Turn off the laptop, and open the lid.
    • Separate the first two layers by prying them apart, using a spudger.
  2. ACER Aspire 7750G-6645 Fan Replacement: Schritt 2, Bild 1 von 3 ACER Aspire 7750G-6645 Fan Replacement: Schritt 2, Bild 2 von 3 ACER Aspire 7750G-6645 Fan Replacement: Schritt 2, Bild 3 von 3
    • Lift the keyboard, so that its ribbon is visible.
    • Remove the ribbon from the board by using a small metal spudger or flathead screwdriver. (if needed)
  3. ACER Aspire 7750G-6645 Fan Replacement, Fan: Schritt 3, Bild 1 von 2 ACER Aspire 7750G-6645 Fan Replacement, Fan: Schritt 3, Bild 2 von 2
    • Remove the two 3mm screws using the Phillips #00 screwdriver.
    • Remove the two 6mm screws using the same screwdriver.
    • Remove the fan cover to gain access to the fan.
  4. ACER Aspire 7750G-6645 Fan Replacement: Schritt 4, Bild 1 von 2 ACER Aspire 7750G-6645 Fan Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Desoldering Pump
    $3.99
    Kaufen
    • Lift the fan up and away from the device. Do not remove the fan from the device.
    • Desolder the attached part using a Soldering Iron to heat it up and remove the leftover heated lead by using a Desoldering Pump.
    • If you aren't familiar with soldering, read our How to Solder and Desolder Connections guide for more information.
Abschluss
taylan ergil
85 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S1-G2, Botvin Spring 2019 Mitglied von UMass Dartmouth, Team S1-G2, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 17
Insgesamt: 625
