Einleitung
This is a replacement guide for the internal cooling fan of a Acer Aspire 7750G-6645. This guide may be helpful if the fan starts to make loud noises or if the computer starts to heat up too much too fast.
Was du brauchst
Turn off the laptop, and open the lid.
Separate the first two layers by prying them apart, using a spudger.
Lift the keyboard, so that its ribbon is visible.
Remove the ribbon from the board by using a small metal spudger or flathead screwdriver. (if needed)
Remove the two 3mm screws using the Phillips #00 screwdriver.
Remove the two 6mm screws using the same screwdriver.
Remove the fan cover to gain access to the fan.
In diesem Schritt verwendetes Werkzeug:Desoldering Pump$3.99
Lift the fan up and away from the device. Do not remove the fan from the device.
Desolder the attached part using a Soldering Iron to heat it up and remove the leftover heated lead by using a Desoldering Pump.
