Zum Hauptinhalt wechseln
Einleitung
The guide is written so the device's microphone can be replaced if it no longer picks up sound.
You will need an opening tool for removing the cover and a soldering kit for removing the wires.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body. Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. The microphone is located in the bottom center of the tablet. Remove the black tape holding the wires down. Remove the black tape holding the microphone in place.
    • The microphone is located in the bottom center of the tablet.
    • Remove the black tape holding the wires down.
    • Remove the black tape holding the microphone in place.
    • The microphone is now exposed and can be gently pulled out of the socket.
  4. You will need a soldering/desoldering kit to desolder the 2 leads where the microphone connects to the circuit board.
    • You will need a soldering/desoldering kit to desolder the 2 leads where the microphone connects to the circuit board.
Abschluss
Brian Graschel
754 Reputation
6 Anleitungen geschrieben
Baylor, Team 4-1, Williams Spring 2015 Mitglied von Baylor, Team 4-1, Williams Spring 2015
BU-WILLIAMS-S15S4G1
3 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 124
