Zum Hauptinhalt wechseln
APEX TM785CH Microphone Replacement
Was du brauchst
  1. APEX TM785CH Microphone Replacement, Back Casing: Schritt 1, Bild 1 von 2 APEX TM785CH Microphone Replacement, Back Casing: Schritt 1, Bild 2 von 2
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. APEX TM785CH Microphone Replacement, Microphone: Schritt 2, Bild 1 von 3 APEX TM785CH Microphone Replacement, Microphone: Schritt 2, Bild 2 von 3 APEX TM785CH Microphone Replacement, Microphone: Schritt 2, Bild 3 von 3
    • The microphone is located in the bottom center of the tablet.
    • Remove the black tape holding the wires down.
    • Remove the black tape holding the microphone in place.
    • The microphone is now exposed and can be gently pulled out of the socket.
  3. APEX TM785CH Microphone Replacement: Schritt 3, Bild 1 von 1
    • You will need a soldering/desoldering kit to desolder the 2 leads where the microphone connects to the circuit board.
Abschluss
Baylor, Team 4-1, Williams Spring 2015 Mitglied von Baylor, Team 4-1, Williams Spring 2015
BU-WILLIAMS-S15S4G1
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 9
Insgesamt: 176
