Zum Hauptinhalt wechseln
APEX TM785CH Speakers Replacement
Was du brauchst
  1. APEX TM785CH Speakers Replacement, Back Casing: Schritt 1, Bild 1 von 2 APEX TM785CH Speakers Replacement, Back Casing: Schritt 1, Bild 2 von 2
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. APEX TM785CH Speakers Replacement, Speakers: Schritt 2, Bild 1 von 3 APEX TM785CH Speakers Replacement, Speakers: Schritt 2, Bild 2 von 3 APEX TM785CH Speakers Replacement, Speakers: Schritt 2, Bild 3 von 3
    • The speakers are located towards the bottom left and bottom right corners of the tablet.
    • If not already done, remove the black tape holding the wires down.
    • Wedge a spudger underneath the speaker in its socket, near where the wires are connected. You can then pry out the speakers.
  3. APEX TM785CH Speakers Replacement: Schritt 3, Bild 1 von 2 APEX TM785CH Speakers Replacement: Schritt 3, Bild 2 von 2
    • You will need a soldering/desoldering kit to desolder the 4 leads where the speakers connect to the circuit board.
Abschluss
Baylor, Team 4-1, Williams Spring 2015 Mitglied von Baylor, Team 4-1, Williams Spring 2015
BU-WILLIAMS-S15S4G1
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 2,588
