Zum Hauptinhalt wechseln
ASUS Chromebook C424MA-DH48F Daughterboard Replacement
Was du brauchst
  1. ASUS Chromebook C424MA-DH48F Daughterboard Replacement, Lower Case: Schritt 1, Bild 1 von 2 ASUS Chromebook C424MA-DH48F Daughterboard Replacement, Lower Case: Schritt 1, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
    • Make sure all the screws on this side get taken out because there could be a label or warranty sticker covering up a screw that might be missed.
    • Insert an opening pick into the gap between the lower case and chassis.
    • Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
    • Remove the lower case.
  2. ASUS Chromebook C424MA-DH48F Daughterboard Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: Schritt 2, Bild 1 von 3 ASUS Chromebook C424MA-DH48F Daughterboard Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: Schritt 2, Bild 2 von 3 ASUS Chromebook C424MA-DH48F Daughterboard Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: Schritt 2, Bild 3 von 3
    • Use an opening tool to pop up the silver locking bar securing the battery connector.
    • Push the battery connector directly out of its motherboard port.
  3. ASUS Chromebook C424MA-DH48F Daughterboard Replacement, Daughterboard: Schritt 3, Bild 1 von 2 ASUS Chromebook C424MA-DH48F Daughterboard Replacement, Daughterboard: Schritt 3, Bild 2 von 2
    • Remove the thermal tape covering the large ribbon cable connector from the daughterboard.
    • Remove the black electrical tape from the small I/O connector on the bottom right corner of the daughterboard.
  4. ASUS Chromebook C424MA-DH48F Daughterboard Replacement: Schritt 4, Bild 1 von 2 ASUS Chromebook C424MA-DH48F Daughterboard Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the four connectors.
    • The cables are thin and delicate, take care when handling to not tear them.
  5. ASUS Chromebook C424MA-DH48F Daughterboard Replacement: Schritt 5, Bild 1 von 1
    • Use a Phillips screwdriver remove the two 1.9 mm screws that secure the board.
  6. ASUS Chromebook C424MA-DH48F Daughterboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the three 3.3 mm screws from the top left hinge bracket.
  7. ASUS Chromebook C424MA-DH48F Daughterboard Replacement: Schritt 7, Bild 1 von 2 ASUS Chromebook C424MA-DH48F Daughterboard Replacement: Schritt 7, Bild 2 von 2
    • Use an opening tool lift the left hinge bracket out of the way of the daughterboard.
  8. ASUS Chromebook C424MA-DH48F Daughterboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the daughterboard by pulling straight up then back towards the motherboard.
Abschluss
Mo3
133 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 53
