Einleitung
If you need to replace your hard drive because it is broken or in need of upgrading, this is the guide for you! In order to go ahead with this guide, you must have already taken the keyboard module off of the laptop. Please visit the prerequisite guide for more details.
Was du brauchst
Use a Philips #1 screwdriver to remove the nine screws from the back cover.
Turn the laptop over and open the display.
Insert the flat edge of the spudger into the crease of the keyboard cover.
While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
Slowly lift the cover open from the front of the laptop, but do not completely remove it.
Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
Remove the four screws that hold the hard drive in place with the Philips #1 screwdriver.
Remove the hard drive by sliding it to the right to disconnect it from the motherboard and lifting out.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
