Zum Hauptinhalt wechseln
ASUS G73JH-BST7 SD Hard Drive Replacement
Was du brauchst
  1. ASUS G73JH-BST7 SD Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 ASUS G73JH-BST7 SD Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the computer over, so that the bottom is facing up.
  2. ASUS G73JH-BST7 SD Hard Drive Replacement: Schritt 2, Bild 1 von 3 ASUS G73JH-BST7 SD Hard Drive Replacement: Schritt 2, Bild 2 von 3 ASUS G73JH-BST7 SD Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Slide the two tabs away from the battery.
    • The left tab will lock, but the right tab must be held away from the battery.
  3. ASUS G73JH-BST7 SD Hard Drive Replacement: Schritt 3, Bild 1 von 3 ASUS G73JH-BST7 SD Hard Drive Replacement: Schritt 3, Bild 2 von 3 ASUS G73JH-BST7 SD Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Use one hand to hold the non-locking tab in place, and use your other hand to pull the battery away from the computer.
  4. ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: Schritt 4, Bild 1 von 3 ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: Schritt 4, Bild 2 von 3 ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: Schritt 4, Bild 3 von 3
    • With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver.
  5. ASUS G73JH-BST7 SD Hard Drive Replacement: Schritt 5, Bild 1 von 3 ASUS G73JH-BST7 SD Hard Drive Replacement: Schritt 5, Bild 2 von 3 ASUS G73JH-BST7 SD Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Carefully pry the panel away from the computer, by lifting with a finger.
    • There is a small tab where a finger will fit to lift the panel away from the computer.
  6. ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: Schritt 6, Bild 1 von 3 ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: Schritt 6, Bild 2 von 3 ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: Schritt 6, Bild 3 von 3
    • Gently pull on the tabs to lift the SD Hard Drives out of the computer.
Abschluss
Deven Rodgers
253 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 369
