Zum Hauptinhalt wechseln
ASUS TUF Gaming FX505DY Charging Port Replacement
Was du brauchst
    1. ASUS TUF Gaming FX505DY Charging Port Replacement, Back Case: Schritt 1, Bild 1 von 1
      • Turn off the laptop.
      • Disconnect the charging cable.
      • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
      • Flip the laptop so the back is facing up.
      Frag FixBot
      Kommentar hinzufügen
    2. ASUS TUF Gaming FX505DY Charging Port Replacement: Schritt 2, Bild 1 von 2 ASUS TUF Gaming FX505DY Charging Port Replacement: Schritt 2, Bild 2 von 2
      • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
      • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
      Frag FixBot
    3. ASUS TUF Gaming FX505DY Charging Port Replacement: Schritt 3, Bild 1 von 2 ASUS TUF Gaming FX505DY Charging Port Replacement: Schritt 3, Bild 2 von 2
      • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
      • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
      Frag FixBot
    4. ASUS TUF Gaming FX505DY Charging Port Replacement: Schritt 4, Bild 1 von 2 ASUS TUF Gaming FX505DY Charging Port Replacement: Schritt 4, Bild 2 von 2
      • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
      Frag FixBot
    1. ASUS TUF Gaming FX505DY Charging Port Replacement, Charging Port: Schritt 5, Bild 1 von 3 ASUS TUF Gaming FX505DY Charging Port Replacement, Charging Port: Schritt 5, Bild 2 von 3 ASUS TUF Gaming FX505DY Charging Port Replacement, Charging Port: Schritt 5, Bild 3 von 3
      • Using an ESD-safe spudger, disconnect the charging port connector by pulling the plug away from its port.
      Frag FixBot
    2. ASUS TUF Gaming FX505DY Charging Port Replacement: Schritt 6, Bild 1 von 2 ASUS TUF Gaming FX505DY Charging Port Replacement: Schritt 6, Bild 2 von 2
      • Remove the two 6mm screws holding the screen hinge and charging port in place using a Phillips #1 screwdriver.
      Frag FixBot
    3. ASUS TUF Gaming FX505DY Charging Port Replacement: Schritt 7, Bild 1 von 3 ASUS TUF Gaming FX505DY Charging Port Replacement: Schritt 7, Bild 2 von 3 ASUS TUF Gaming FX505DY Charging Port Replacement: Schritt 7, Bild 3 von 3
      • Firmly lift the screen hinge out of the way.
      • The hinge supports the weight of the screen, so it is stiff. Use consistent force.
      Frag FixBot
    4. ASUS TUF Gaming FX505DY Charging Port Replacement: Schritt 8, Bild 1 von 1
      • Remove the charging port by lifting it free of the hole in the case.
      • It may require some shifting or angling to come free.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 2-4, Mellen Spring 2022 Mitglied von UMass Dartmouth, Team 2-4, Mellen Spring 2022
UMASSD-MELLEN-S22S2G4
4 Mitglieder
79 Anleitungen geschrieben
1 Kommentar zur Anleitung
hi,
Very useful thanks,
I cma ein this post as my usb-c port look has a fiscal damage, do you have any experience on that and what may be your thoughts ? can be fixed?
Enton Qesari - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 70
Insgesamt: 3,339
