Zum Hauptinhalt wechseln
ASUS TUF Gaming FX505DY RAM Replacement
Was du brauchst
  1. ASUS TUF Gaming FX505DY RAM Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY RAM Replacement: Schritt 2, Bild 1 von 2 ASUS TUF Gaming FX505DY RAM Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY RAM Replacement: Schritt 3, Bild 1 von 2 ASUS TUF Gaming FX505DY RAM Replacement: Schritt 3, Bild 2 von 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY RAM Replacement: Schritt 4, Bild 1 von 2 ASUS TUF Gaming FX505DY RAM Replacement: Schritt 4, Bild 2 von 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY RAM Replacement, RAM: Schritt 5, Bild 1 von 2 ASUS TUF Gaming FX505DY RAM Replacement, RAM: Schritt 5, Bild 2 von 2
    • Pull the motherboard clips away from the sides of the RAM chip.
    • The RAM chip will pop up at an angle.
  6. ASUS TUF Gaming FX505DY RAM Replacement: Schritt 6, Bild 1 von 1
    • At an angle, gently but firmly pull the RAM chip to remove it from the slot.
    • To install RAM, insert the RAM into the slot and press flat until the clips make an audible "click."
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 2-4, Mellen Spring 2022 Mitglied von UMass Dartmouth, Team 2-4, Mellen Spring 2022
UMASSD-MELLEN-S22S2G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 42
Insgesamt: 1,819
