Einleitung
A fan is included within a computer to help ensure it will not overheat. If the fan within your ASUS Vivobook S300CA-BB15T01 isn't working, please follow the steps below to replace it.
Was du brauchst
Unscrew the following 10 screws
Eight 5 mm Phillips head screws
Two 10 mm Phillips head screws
Remove the following 6 screws:
Two 5 mm screws holding the fan down.
Four 3 mm screws holding the heat sink down
Carefully disconnect the only sliding connector by using a plastic opening tool to pry the connector out.
