Zum Hauptinhalt wechseln
ASUS X533SA-BHCLN10 Optical Disc Drive Replacement
Was du brauchst
  1. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement, Battery: Schritt 1, Bild 1 von 2 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn over the laptop on the back panel.
    • Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
  2. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: Schritt 2, Bild 1 von 2 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: Schritt 2, Bild 2 von 2
    • Turn over the laptop with the keyboard facing upwards.
    • Using a small prying or opening tool, stick the prying tool under the edge of the laptop.
  3. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: Schritt 3, Bild 1 von 2 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: Schritt 3, Bild 2 von 2
    • After the laptop is completely pried open carefully remove the keyboard from the laptop.
    • There are two small keyboard cables connecting the keyboard to the laptop. Carefully remove these by popping up the white clips holding them in place and slide the connector out.
  4. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement, Optical Disc Drive: Schritt 4, Bild 1 von 2 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement, Optical Disc Drive: Schritt 4, Bild 2 von 2
    • Remove all 3 screws with the screwdriver.
    • The top left screw is 5.5 mm and the bottom two screws are 2.5 mm.
  5. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: Schritt 5, Bild 1 von 3 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: Schritt 5, Bild 2 von 3 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: Schritt 5, Bild 3 von 3
    • Gently, push the optical drive part from inside to remove the drive from the motherboard socket.
    • While replacing, make sure the optical drive is connected to the socket of the motherboard (denoted by the red rectangle).
Abschluss
Edmund Lee
473 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S13-G3, Boczar Fall 2017 Mitglied von USF Tampa, Team S13-G3, Boczar Fall 2017
USFT-BOCZAR-F17S13G3
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 187
