Zum Hauptinhalt wechseln
ASUS X533SA-BHCLN10 Wi-Fi Card Replacement
Was du brauchst
  1. ASUS X533SA-BHCLN10 Wi-Fi Card Replacement, Battery: Schritt 1, Bild 1 von 2 ASUS X533SA-BHCLN10 Wi-Fi Card Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn over the laptop on the back panel.
    • Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
    Frag FixBot
    Kommentar hinzufügen
  2. ASUS X533SA-BHCLN10 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 ASUS X533SA-BHCLN10 Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • Turn over the laptop with the keyboard facing upwards.
    • Using a small prying or opening tool, stick the prying tool under the edge of the laptop.
    Frag FixBot
  3. ASUS X533SA-BHCLN10 Wi-Fi Card Replacement: Schritt 3, Bild 1 von 2 ASUS X533SA-BHCLN10 Wi-Fi Card Replacement: Schritt 3, Bild 2 von 2
    • After the laptop is completely pried open carefully remove the keyboard from the laptop.
    • There are two small keyboard cables connecting the keyboard to the laptop. Carefully remove these by popping up the white clips holding them in place and slide the connector out.
    Frag FixBot
  4. ASUS X533SA-BHCLN10 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 4, Bild 1 von 2 ASUS X533SA-BHCLN10 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 4, Bild 2 von 2
    • Remove the Phillips #0 screws securing the motherboard to laptop.
    Frag FixBot
  5. ASUS X533SA-BHCLN10 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 2 ASUS X533SA-BHCLN10 Wi-Fi Card Replacement: Schritt 5, Bild 2 von 2
    • Remove the wire that's attached to the motherboard on top with a pop up motion.
    Frag FixBot
  6. ASUS X533SA-BHCLN10 Wi-Fi Card Replacement: Schritt 6, Bild 1 von 3 ASUS X533SA-BHCLN10 Wi-Fi Card Replacement: Schritt 6, Bild 2 von 3 ASUS X533SA-BHCLN10 Wi-Fi Card Replacement: Schritt 6, Bild 3 von 3
    • Push on the VGA port and wiggle the motherboard out.
    Frag FixBot
  7. ASUS X533SA-BHCLN10 Wi-Fi Card Replacement: Schritt 7, Bild 1 von 3 ASUS X533SA-BHCLN10 Wi-Fi Card Replacement: Schritt 7, Bild 2 von 3 ASUS X533SA-BHCLN10 Wi-Fi Card Replacement: Schritt 7, Bild 3 von 3
    • Lift the motherboard up carefully.
    • There is another wire securing the motherboard to the monitor from the bottom (DO NOT remove the wire) denoted by the red circle.
    Frag FixBot
  8. ASUS X533SA-BHCLN10 Wi-Fi Card Replacement: Schritt 8, Bild 1 von 2 ASUS X533SA-BHCLN10 Wi-Fi Card Replacement: Schritt 8, Bild 2 von 2
    • Remove the Wi-Fi card from the motherboard.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team S13-G3, Boczar Fall 2017 Mitglied von USF Tampa, Team S13-G3, Boczar Fall 2017
USFT-BOCZAR-F17S13G3
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 780
