Zum Hauptinhalt wechseln
ATT EL52300 LCD Screen on Handset Replacement
Was du brauchst
  1. ATT EL52300 LCD Screen on Handset Replacement, Battery: Schritt 1, Bild 1 von 2 ATT EL52300 LCD Screen on Handset Replacement, Battery: Schritt 1, Bild 2 von 2
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
  2. ATT EL52300 LCD Screen on Handset Replacement: Schritt 2, Bild 1 von 1
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
  3. ATT EL52300 LCD Screen on Handset Replacement, Motherboard: Schritt 3, Bild 1 von 2 ATT EL52300 LCD Screen on Handset Replacement, Motherboard: Schritt 3, Bild 2 von 2
    • Remove the two 3.75 mm screws with a PH1 screwdriver.
  4. ATT EL52300 LCD Screen on Handset Replacement: Schritt 4, Bild 1 von 2 ATT EL52300 LCD Screen on Handset Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to remove the handset case.
    • Be careful to not lift the case too far as the ringer cable is attached to the case.
  5. ATT EL52300 LCD Screen on Handset Replacement: Schritt 5, Bild 1 von 2 ATT EL52300 LCD Screen on Handset Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
    • Use an anti-static wrist strap to prevent damage to the motherboard.
  6. ATT EL52300 LCD Screen on Handset Replacement, LCD Screen on Handset: Schritt 6, Bild 1 von 2 ATT EL52300 LCD Screen on Handset Replacement, LCD Screen on Handset: Schritt 6, Bild 2 von 2
    • The motherboard is connected to the ringer, which is clipped on to the back plate of your handset.
    • Pop off the indicated clip using a pointed tweezer.
    • With the motherboard disconnected from the back plate, turn it over so that the screen is facing you.
  7. ATT EL52300 LCD Screen on Handset Replacement: Schritt 7, Bild 1 von 3 ATT EL52300 LCD Screen on Handset Replacement: Schritt 7, Bild 2 von 3 ATT EL52300 LCD Screen on Handset Replacement: Schritt 7, Bild 3 von 3
    • To get to the connection between the display and the motherboard, remove the casing for the display using a plastic opening tool.
    • The white casing has a hole cut into it. You are going to slide the display and the speaker through this hole.
  8. ATT EL52300 LCD Screen on Handset Replacement: Schritt 8, Bild 1 von 1
Abschluss
Katty
313 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 1-1, Sullivan Spring 2016 Mitglied von USF Tampa, Team 1-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 437
