Einleitung
This guide will show you how to replace the speaker for your EL52300 handset. This guide involves direct contact with the motherboard, as well as use of a soldering tool. Any safety precautions present in the motherboard replacement guide for this device, or the soldering guide for this website must be followed.
Was du brauchst
Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
Unplug the battery by squeezing your hands on the small white plug and lifting it up.
The battery is now detached and ready to be removed by lifting it out.
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
Using the soldering tool, disconnect the speaker from your handset's motherboard.
