Einleitung
Use this guide to replace the Wi-Fi card in a Acer Aspire 3 A315-58-350L.
Was du brauchst
Insert an opening tool into the seam between the lower case and chassis.
Pry along the perimeter until the lower case releases.
Lift off the lower case.
Use an opening tool to lift and disconnect the Wi-Fi card antenna cables.
Remove the single 2 mm Phillips screw that secures the Wi-Fi card.
Pull the Wi-Fi card directly out of its socket.
