Was du brauchst
To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
Remove the fourteen M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
Slowly rotate the back cover up to reveal cables attached to the motherboard.
Carefully slide the connectors out of their receptacle to remove the back panel.
Open the up the laptop to reveal the CMOS battery.
Desolder the CMOS battery to remove it. For soldering help, check out iFixit's soldering guide.
6 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
molto utile e ben fatta, anche se il mio problema è più legato alla alimentazione che pare non funzionare anche senza batteria
It'd be really handy if you were to list the model number of the CMOS battery so we can order one in advance.
