Zum Hauptinhalt wechseln
Acer Aspire E5-571 Keyboard Replacement
Was du brauchst
  1. Acer Aspire E5-571 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 1
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 Keyboard Replacement: Schritt 5, Bild 1 von 3 Acer Aspire E5-571 Keyboard Replacement: Schritt 5, Bild 2 von 3 Acer Aspire E5-571 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips. Do not remove the keyboard until told to do so.
  6. Acer Aspire E5-571 Keyboard Replacement: Schritt 6, Bild 1 von 2 Acer Aspire E5-571 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Carefully flip up the white hinge. Then, detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
daniel sawyer
2.566 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 4-2, Meier Fall 2015 Mitglied von USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
3 Mitglieder
4 Kommentare
keyboard cable is a b$%*h
shrs - Antwort
can you explain how to remove the keyboard and attach the new one to the whole top
christhesoccerkid - Antwort
keyboard cable is indeed a b$%*h, but you will get there with the patience of a zen master
here's a video that shows the extra steps of remo9ving and replacing keyboard: https://www.youtube.com/watch?v=DpawPQrq...
tom - Antwort
I'm only 13 and it was easy to get to the dvd-rw drive and unjam it, little hands made the keyboard cable a breeze.
tha B-BOY - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 38
Insgesamt: 12,197
