Einleitung
If your Acer Aspire E5-571P-55TL is not holding a charge, or won't turn on at all, the battery may be damaged or run out of power. The battery is a component that supplies power to the device, allowing it to work without a power cord. Over many charges, the temporary lifespan of the battery decreases. To see common issues which may require battery replacement, see our Acer E5-571P-55TL troubleshooting guide.
This guide will explain how to replace the battery for the Acer E5-571P-55TL. Before performing actions in this guide be sure to power off your laptop and remove the power adapter.
If the battery you are replacing looks damaged or swollen be careful handling it. Damaged batteries may be potentially hazardous. Use caution when handling the damaged battery.
Was du brauchst
Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
