Zum Hauptinhalt wechseln
Acer Aspire E5-573G Battery Replacement
Was du brauchst
  1. Acer Aspire E5-573G Battery Replacement, Optical Drive: Schritt 1, Bild 1 von 1
    • Ensure your device is OFF before beginning this procedure.
    • Unscrew the 5 mm Phillips head screw holding the drive in place.
  2. Acer Aspire E5-573G Battery Replacement: Schritt 2, Bild 1 von 1
    • Pull out the disk drive.
  3. Acer Aspire E5-573G Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Unscrew the seventeen 5 mm Phillips head screws from the bottom cover.
  4. Acer Aspire E5-573G Battery Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the three 2.5 mm Phillips head screws underneath the optical drive bay.
  5. Acer Aspire E5-573G Battery Replacement: Schritt 5, Bild 1 von 1
    • Run a pick between the bottom cover and the device around the edge of the laptop and unclip the cover from the rest of the device.
  6. Acer Aspire E5-573G Battery Replacement: Schritt 6, Bild 1 von 1
    • Lift the left side of the bottom cover, but do not completely remove the cover, as the speaker is cable is still connected and will be damaged.
    • Pull the speaker connector towards the fan to disconnect it from its socket on the motherboard.
  7. Acer Aspire E5-573G Battery Replacement: Schritt 7, Bild 1 von 1
    • Pull the battery connector towards the battery to disconnect it from its socket on the motherboard.
    • Remove the battery.
Abschluss
14 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Bahm
2.226 Reputation
6 Anleitungen geschrieben
Cal Poly, Team S12-G5, Banghart Winter 2018 Mitglied von Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
2 Mitglieder
15 Anleitungen geschrieben
Ein Kommentar
Where can i buy a battery replacement for my aspire e5-573g-59c3?
mfortich98 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 67
Insgesamt: 21,658
