Zum Hauptinhalt wechseln
Acer Aspire One 725-0845 Hard Drive Replacement
Was du brauchst
  1. Acer Aspire One 725-0845 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Acer Aspire One 725-0845 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Acer Aspire One 725-0845 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Acer Aspire One 725-0845 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Acer Aspire One 725-0845 Hard Drive Replacement, Back Plate: Schritt 3, Bild 1 von 3 Acer Aspire One 725-0845 Hard Drive Replacement, Back Plate: Schritt 3, Bild 2 von 3 Acer Aspire One 725-0845 Hard Drive Replacement, Back Plate: Schritt 3, Bild 3 von 3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Acer Aspire One 725-0845 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 Acer Aspire One 725-0845 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
  5. Acer Aspire One 725-0845 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Using your hand, slide the hard drive away from the center of the device until it disconnects from the motherboard.
    • Carefully lift the outward side of the hard drive and place the drive on a clean, non-magnetic surface.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Jose Souto
337 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 8-3, Eyestone Spring 2017 Mitglied von USF Tampa, Team 8-3, Eyestone Spring 2017
USFT-EYESTONE-S17S8G3
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 1,471
