Zum Hauptinhalt wechseln
Acer Aspire One 725-0845 Touchpad Replacement
Was du brauchst
  1. Acer Aspire One 725-0845 Touchpad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
    Frag FixBot
    Kommentar hinzufügen
  2. Acer Aspire One 725-0845 Touchpad Replacement: Schritt 2, Bild 1 von 3 Acer Aspire One 725-0845 Touchpad Replacement: Schritt 2, Bild 2 von 3 Acer Aspire One 725-0845 Touchpad Replacement: Schritt 2, Bild 3 von 3
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
    Frag FixBot
  3. Acer Aspire One 725-0845 Touchpad Replacement, Back Plate: Schritt 3, Bild 1 von 3 Acer Aspire One 725-0845 Touchpad Replacement, Back Plate: Schritt 3, Bild 2 von 3 Acer Aspire One 725-0845 Touchpad Replacement, Back Plate: Schritt 3, Bild 3 von 3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
    Frag FixBot
  4. Acer Aspire One 725-0845 Touchpad Replacement, Hard Drive: Schritt 4, Bild 1 von 2 Acer Aspire One 725-0845 Touchpad Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
    Frag FixBot
  5. Acer Aspire One 725-0845 Touchpad Replacement: Schritt 5, Bild 1 von 1
    • Using your hand, slide the hard drive away from the center of the device until it disconnects from the motherboard.
    • Carefully lift the outward side of the hard drive and place the drive on a clean, non-magnetic surface.
    Frag FixBot
  6. Acer Aspire One 725-0845 Touchpad Replacement, Inner Frame: Schritt 6, Bild 1 von 3 Acer Aspire One 725-0845 Touchpad Replacement, Inner Frame: Schritt 6, Bild 2 von 3 Acer Aspire One 725-0845 Touchpad Replacement, Inner Frame: Schritt 6, Bild 3 von 3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the six outside screws (7.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the seven inside screws (8.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the one inside screw (3.0 mm).
    Frag FixBot
  7. Acer Aspire One 725-0845 Touchpad Replacement: Schritt 7, Bild 1 von 3 Acer Aspire One 725-0845 Touchpad Replacement: Schritt 7, Bild 2 von 3 Acer Aspire One 725-0845 Touchpad Replacement: Schritt 7, Bild 3 von 3
    • Using your hands, slide the brown release tabs for the keyboard connection away from the center of the device.
    • Gently remove the keyboard connection by pulling away from the center of the device.
    • Lift the black locks for the touchpad connections into the upward position.
    • Gently remove the touchpad connections by pulling the purple tabs away from the locks.
    Frag FixBot
  8. Acer Aspire One 725-0845 Touchpad Replacement: Schritt 8, Bild 1 von 3 Acer Aspire One 725-0845 Touchpad Replacement: Schritt 8, Bild 2 von 3 Acer Aspire One 725-0845 Touchpad Replacement: Schritt 8, Bild 3 von 3
    • Flip the device over and open it.
    • Using the plastic opening tools, remove the cover/palm rest from the frame of the device.
    Frag FixBot
  9. Acer Aspire One 725-0845 Touchpad Replacement, Keyboard: Schritt 9, Bild 1 von 2 Acer Aspire One 725-0845 Touchpad Replacement, Keyboard: Schritt 9, Bild 2 von 2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the 17 screws (3.0 mm) from the back of the keyboard.
    Frag FixBot
  10. Acer Aspire One 725-0845 Touchpad Replacement: Schritt 10, Bild 1 von 2 Acer Aspire One 725-0845 Touchpad Replacement: Schritt 10, Bild 2 von 2
    • Remove the keyboard by lifting up and away from the cover/palm rest. Be careful with the keyboard connection during this step.
    • To replace an individual key, remove the key from the keyboard using a plastic opening tool.
    Frag FixBot
  11. Acer Aspire One 725-0845 Touchpad Replacement, Touchpad: Schritt 11, Bild 1 von 2 Acer Aspire One 725-0845 Touchpad Replacement, Touchpad: Schritt 11, Bild 2 von 2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (7.0 mm) from touchpad buttons.
    Frag FixBot
  12. Acer Aspire One 725-0845 Touchpad Replacement: Schritt 12, Bild 1 von 2 Acer Aspire One 725-0845 Touchpad Replacement: Schritt 12, Bild 2 von 2
    • On the cover/palm rest, lift the black locks for the touchpad buttons into the upward position.
    • Remove the connection for the touchpad buttons by gently pulling the purple tabs away from the locks.
    • Remove touchpad buttons by lifting them up and away from the cover/palm rest.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 8-3, Eyestone Spring 2017 Mitglied von USF Tampa, Team 8-3, Eyestone Spring 2017
USFT-EYESTONE-S17S8G3
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 1,772
