Einleitung
The USB port allows you to connect other devices to the laptop. This guide will show you how to remove and replace the USB port.
Was du brauchst
Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
Remove the ribbon cable from the socket.
Remove the 5mm Phillips #0 screw from the USB port.
Remove the USB port from the device.
