Einleitung
Changing the Battery in an Acer Aspire R7 is a straightforward process if you find your computer has lost its ability to hold a charge.
The Aspire laptop battery enables the computer to work without having a power cord. It is a hardware component that is not externally accessible and requires a small amount of disassembly to replace.
The 4-cell replacement battery instructions are listed below in quick simple steps. Before using this guide make sure that the battery can no longer function in one of two ways, use a multimeter to test battery strength or check the settings on the laptop if possible.
If the battery is swollen be careful and proceed with caution and take appropriate precautions.
Was du brauchst
Shut down the laptop and disconnect the power cord.
Turn the laptop over.
Remove seven 10 mm T7 screws.
Remove four 6 mm T7 screws.
Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
Remove the remaining four 10 mm T7 screws.
Locate the battery ribbon connector
Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
Push the 4 retaining clips away from the battery
Carefully lift the battery from the motherboard
12 weitere Personen haben diese Anleitung absolviert.
6 Kommentare
great instructions
hey how do you want då sel it for
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
