Zum Hauptinhalt wechseln
Acer Aspire R7 Battery Replacement
Was du brauchst
    1. Acer Aspire R7 Battery Replacement, Cover: Schritt 1, Bild 1 von 1
      • Shut down the laptop and disconnect the power cord.
      • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
      • Turn the laptop over.
      Frag FixBot
      Kommentar hinzufügen
    2. Acer Aspire R7 Battery Replacement: Schritt 2, Bild 1 von 3 Acer Aspire R7 Battery Replacement: Schritt 2, Bild 2 von 3 Acer Aspire R7 Battery Replacement: Schritt 2, Bild 3 von 3
      • Remove six 6mm T7 screws.
      • Remove four 4mm T7 screws.
      • Remove two 10mm T7 screws
      • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
      • Remove the remaining two10mm T7 screws.
      Frag FixBot
    3. Acer Aspire R7 Battery Replacement: Schritt 3, Bild 1 von 1
      • Carefully lift the cover upwards.
      • If the cover seems stuck, use a spudger tool to pry the sides.
      Frag FixBot
    1. Acer Aspire R7 Battery Replacement, Battery: Schritt 4, Bild 1 von 2 Acer Aspire R7 Battery Replacement, Battery: Schritt 4, Bild 2 von 2
      • Locate the battery ribbon connector
      • Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
      • When using the spudger be careful around the motherboard as it can easily be damaged
      Frag FixBot
    2. Acer Aspire R7 Battery Replacement: Schritt 5, Bild 1 von 3 Acer Aspire R7 Battery Replacement: Schritt 5, Bild 2 von 3 Acer Aspire R7 Battery Replacement: Schritt 5, Bild 3 von 3
      • Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
      • Push the 4 retaining clips away from the battery
      • Carefully lift the battery from the motherboard
      Frag FixBot
Abschluss
12 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 3-4, Hickman Winter 2015 Mitglied von USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Mitglieder
72 Anleitungen geschrieben
6 Kommentare zur Anleitung
great instructions
amaryheart7777777 - Antwort Teilen
What is the battery reference for replacement ?
skalpinou - Antwort Teilen
which battery model do I purchase for replacing on an Acer Aspire R?
Eddie - Antwort Teilen
hey how do you want då sel it for
Alex santos - Antwort Teilen
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
Anthymoine - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 49
Insgesamt: 42,409
