Zum Hauptinhalt wechseln
Acer Aspire V5-571-6889 Display Assembly Replacement
Was du brauchst
  1. Acer Aspire V5-571-6889 Display Assembly Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Flip laptop over so that the back is facing upward.
    • Push switch to the right.
    • Pull battery away from the laptop.
  2. Acer Aspire V5-571-6889 Display Assembly Replacement: Schritt 2, Bild 1 von 1
    • Use a #0 Phillips head screw driver to remove all of the screws.
  3. Acer Aspire V5-571-6889 Display Assembly Replacement: Schritt 3, Bild 1 von 1
    • Flip laptop back over.
    • Open the laptop.
    • Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
    • Be careful not to bend the keyboard too much or break the tabs that connect the keyboard to the laptop.
  4. Acer Aspire V5-571-6889 Display Assembly Replacement: Schritt 4, Bild 1 von 1
    • Gently lift keyboard.
    • Disconnect keyboard from the laptop.
  5. Acer Aspire V5-571-6889 Display Assembly Replacement, Remove Upper Cover: Schritt 5, Bild 1 von 1
    • Disconnect the two ribbon cables at the near left.
    • Remove six screws: ⁃ one by the left most ribbon cable connector ⁃ one mid-right center ⁃ one on the near edge left of center ⁃ three across the back
    • Use a prying tool to remove the upper cover.
  6. Acer Aspire V5-571-6889 Display Assembly Replacement: Schritt 6, Bild 1 von 1
    • Locate the hard drive.
    • Lift the hard drive.
    • Disconnect hard drive.
  7. Acer Aspire V5-571-6889 Display Assembly Replacement, Display Assembly: Schritt 7, Bild 1 von 1
    • Remove the top left screw that is connecting the display assembly and the body of the laptop.
    • Remove the 2.5 mm by 5 mm screw by using #0 Phillips head screw driver.
  8. Acer Aspire V5-571-6889 Display Assembly Replacement: Schritt 8, Bild 1 von 1
    • Using a #0 Phillips screw driver, remove the other 2.5 mm by 5 mm phillips screw that holds the display assembly.
  9. Acer Aspire V5-571-6889 Display Assembly Replacement: Schritt 9, Bild 1 von 1
    • Gently disconnect the display cable connector between the display assembly and the motherboard.
  10. Acer Aspire V5-571-6889 Display Assembly Replacement: Schritt 10, Bild 1 von 1
    • Remove the tape holding down the display cable that connects it to the motherboard.
  11. Acer Aspire V5-571-6889 Display Assembly Replacement: Schritt 11, Bild 1 von 1
    • Disconnect the tape that is holding the white antenna cable to the motherboard.
  12. Acer Aspire V5-571-6889 Display Assembly Replacement: Schritt 12, Bild 1 von 1
    • Take the display assembly off and replace it with a new one.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Mohd Yuthly
154 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G4, Harley Summer 2019 Mitglied von IUPUI, Team S2-G4, Harley Summer 2019
IUPUI-HARLEY-SU19S2G4
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 886
