Einleitung
This guide will show how to replace the keyboard on a Acer Aspire V5-571P-6815 laptop.
Was du brauchst
Insert a plastic opening tool underneath the keyboard and pry upwards.
Slide the plastic opening tool around the perimeter to free the keyboard.
Flip the keyboard over and onto the palm rest.
Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Pull the ribbon cable out of the socket.
Remove the keyboard from the laptop.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
This guide is wrong. All keyboard sold online come without the frame and replacing the keyboard is actually a very tedious process as it’s attached with melt plastic.
Thank you! All this guide shows is how to take out and put in the exact same keyboard, which doesn't seem to be available anywhere. I've been looking for an exact replacement and haven't been able to find one. The original keyboard has the frame with the power button. NONE of the replacement options has ANYTHING with the power button.
