Zum Hauptinhalt wechseln
Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement
Was du brauchst
  1. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: Schritt 5, Bild 1 von 3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: Schritt 5, Bild 2 von 3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: Schritt 5, Bild 3 von 3
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 6, Bild 1 von 2 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Lift the battery out gently.
  8. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Disconnect the LCD cable from the motherboard by removing the tape on the LCD connector, then gently pulling out the ribbon cable.
  9. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 9, Bild 1 von 3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 9, Bild 2 von 3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Disconnect the LCD cable from the motherboard by gently pulling on the cable.
  10. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Disconnect the trackpad by pulling on the trackpad connector cable.
  11. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 11, Bild 1 von 2 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Disconnect the daughterboard from the motherboard by gently removing the daughterboard cable from the motherboard connector.
  12. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 12, Bild 1 von 2 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Remove the electrical tape covering the screw that holds the Wi-Fi card in place.
    • Remove the single 4mm JIS #0 screw that holds the Wi-Fi card in place.
  13. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Remove the seven 4mm JIS #0 screws that hold the motherboard in place.
  14. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Gently remove the motherboard.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 21
Insgesamt: 1,876
