Einleitung
If you have distorted, or no audio coming from the speakers in your Acer Chromebook 14 CB3-431-C3WS, you may need to replace the speakers in your laptop.
Consider looking at the troubleshooting page to see if there may be a simpler solution.
Was du brauchst
Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
After the sides have been lifted, use the opening tool to finish opening the back cover.
Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
Lift the speakers from the frame, making sure to carefully unwind the wires connecting the speakers.
2 weitere Personen haben diese Anleitung absolviert.
