Einleitung
This guide will walk you through replacing the fan from your Acer Chromebook 15 CB5-571-C09S.
Was du brauchst
Place the device on a flat surface faced down so that the fan vents are at the top of the device.
Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
Use a plastic opening tool to pry open the back cover around the edges of the device.
Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
Unscrew the four 3 mm PH00 Phillips screws located on the corner edges of the brass colored piece of metal.
Disconnect the fan connector from the motherboard using two plastic opening tools.
Grab the fan by its cover and the brass colored piece of metal and carefully lift up and pull out the fan from the device.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Thanks for the guide. I was able to successfully replace my fan using it. I would like to point out a couple of things:
1. 10 minutes is not a realistic completion time for this guide.
2. Disconnecting the fan plug is challenging. It might have been easier with a small pair of pliers.
3. Since this guide involves dis/re-connecting the thermal interface between the processor and heat sink, you should be prepared to properly clean both surfaces and re-apply new thermal compound. There is an excellent guide on applying thermal compound here:
