Zum Hauptinhalt wechseln
Acer Chromebook C710-2833 Wifi Card Replacement
Was du brauchst
  1. Acer Chromebook C710-2833 Wifi Card Replacement, Wifi Card: Schritt 1, Bild 1 von 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 2, Bild 2 von 2
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
  3. Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 4, Bild 1 von 1
    • Locate the 3 mm Phillips #00 screw on the wireless card port.
    • Unscrew the screw and place it aside for now.
  5. Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 5, Bild 1 von 3 Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 5, Bild 2 von 3 Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 5, Bild 3 von 3
    • Safely remove the wireless card by pulling it out of the bottom of the port.
    • Lastly, disconnect the two white and black wire connectors attached to the wireless card.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team S1-G6, Nance Fall 2017 Mitglied von USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
4 Mitglieder
10 Anleitungen geschrieben
1 Kommentar zur Anleitung
Replaced the original wifi card, how do you get Chrome OS to recognize, or find and download driver for Intel AC 7260 wifi card?
Thanks.
When Ze - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 802
