Einleitung
This guide explains how to replace your Chromebook's RAM. You will need to remove the Back Panel Assembly first. Then, you will need to remove the Battery and Speakers. Next, you will need to remove the Hard Drive. Then, you will need to remove the USB ports / SD Card Reader. After, you will need to take the Motherboard out to get to the RAM.
Was du brauchst
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
Remove the single 3.0mm screw securing the solid state drive using a Phillips #1 screwdriver.
Remove the three 6.0mm screws using the Phillips #1 screwdriver.
Remove the two 3.0mm screws using the Phillips #1 screwdriver.
Position the spudger under the switch that connects the ribbon cable to the motherboard.
Flick the spudger up to flip the switch up.
Grab the edges of each piece of circuitry that is included with the SD Card Reader and USB Port.
Pull each piece of circuitry out of the Chromebook and remove it from the device.
Position the spudger under the switch.
Pull on the blue tab of the ribbon cable to remove the ribbon cable.
Repeat the previous step and this step with the other ribbon cable that is attached to the SD Card Reader/USB Port.
Using the Phillips #1 screwdriver, remove the four 3.0mm screws.
Loosen the six 3.0mm CPU screws using the Phillips #1 screwdriver.
Grab the wire for the two pin connector.
Pull the wire to disconnect it from the motherboard.
Place the back of the spudger under the black wire that connects the wireless card to the motherboard.
Flick the spudger up to disconnect the cable from the motherboard.
Place the back of the spudger under the white coaxial antenna wire that connects the wireless card to the motherboard.
Firmly grasp the red, yellow, and white cords with two fingers.
Pull the cords to unplug it.
Position the spudger under the switch of the big ribbon cable.
Grab the blue tab of the ribbon cable.
Pull on the blue tab to disconnect the ribbon cable.
Grab the red and black cable near the display cables, this is the cable to the other two pin connector.
Pull on the wire to disconnect it from the motherboard.
Flip the wire and the connector up to move it out of the way.
Position the spudger under the switch for the smaller ribbon cable.
Flick the spudger up to flip the smaller switch up.
Grab the blue tab on the ribbon cable.
Pull on the tab to disconnect the ribbon cable from the motherboard.
Position the back of the spudger at the edge of the tape that holds the display cable in.
Peel the tape back so it is out of the way.
Position the back of the spudger on the display cable.
Push the display cable out using the back of the spudger.
Lift up the CPU fan to ensure that no wires are tangled. If the black and white wires are tangles please repeat step 5.
Lift up the other end of the motherboard to completely remove the motherboard.
Carefully desolder the sides of the old RAM using a soldering iron.
For soldering help, visit iFixit's How to Solder and Desolder Connections guide.
Eine weitere Person hat diese Anleitung absolviert.
