Zum Hauptinhalt wechseln
Acer Chromebook CB3-431-C5EX Display Replacement
Was du brauchst
  1. Acer Chromebook CB3-431-C5EX Display Replacement, Display: Schritt 1, Bild 1 von 1
    • Make sure the work area is clean and free from dirt and debris.
    • Open the lid of the laptop.
    • Place the laptop so the screen is facing upwards and the outside of the laptop is flat against a table.
  2. Acer Chromebook CB3-431-C5EX Display Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook CB3-431-C5EX Display Replacement: Schritt 2, Bild 2 von 2
    • Carefully insert an opening tool under the screen bezel and gently pry it away from the edge of the screen.
    • Slowly slide the opening tool around the bezel on all four sides to separate it from the screen.
    • Be careful to not damage any wires that are under the bezel, or crack the bezel itself.
  3. Acer Chromebook CB3-431-C5EX Display Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 2.8 mm screws from the screen using a Phillips #0 screwdriver and place them to the side for use later.
    • Be careful to not touch the tape protecting the display circuit board.
  4. Acer Chromebook CB3-431-C5EX Display Replacement: Schritt 4, Bild 1 von 3 Acer Chromebook CB3-431-C5EX Display Replacement: Schritt 4, Bild 2 von 3 Acer Chromebook CB3-431-C5EX Display Replacement: Schritt 4, Bild 3 von 3
    • Gently lay the screen against the keyboard.
    • Carefully remove the adapter connecting the display to the motherboard.
  5. Acer Chromebook CB3-431-C5EX Display Replacement: Schritt 5, Bild 1 von 1
    • Once you have separated the screen from the motherboard, carefully remove the display from the laptop.
Abschluss
To reassemble your device, follow these instructions using a replacement screen, in reverse order.
Ethan
121 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 327
