Zum Hauptinhalt wechseln
Acer Chromebook CB3-532-C47C Keyboard Keys Replacement
Was du brauchst
  1. Acer Chromebook CB3-532-C47C Keyboard Keys Replacement, Keyboard Keys: Schritt 1, Bild 1 von 1
    • Place the plastic opening tool directly underneath the key and pry upwards to remove the key.
    • Do not use too much force to avoid separating the retainer clip on the keyboard.
  2. Acer Chromebook CB3-532-C47C Keyboard Keys Replacement: Schritt 2, Bild 1 von 1
    • Repeat with each key that needs to be removed.
    • If you are removing the keys in order to clean the keyboard, please refer to the troubleshooting guide to complete this process.
Abschluss
To reassemble your device, press the keys back onto the keyboard so that the figures are facing you.
Sadie Brown
967 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 3-2, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G2
3 Mitglieder
Ein Kommentar
1 key has different commands. D key redirects to download, E key highlights and deletes texts and replaces it with Q, number 3 key types lots of numbers, C key types lots of letters. How can I fix this and what coulf be the possible cause of this?
Ryo Heil - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 29
Insgesamt: 357
