Zum Hauptinhalt wechseln
Acer Chromebook CB3-532-C47C Speaker Replacement
Was du brauchst
  1. Acer Chromebook CB3-532-C47C Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 2 Acer Chromebook CB3-532-C47C Speaker Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Speaker Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook CB3-532-C47C Speaker Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Speaker Replacement, Remove the battery cable: Schritt 3, Bild 1 von 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Speaker Replacement, Disconnect the Speakers: Schritt 4, Bild 1 von 2 Acer Chromebook CB3-532-C47C Speaker Replacement, Disconnect the Speakers: Schritt 4, Bild 2 von 2
    • Pull the black ribbon attached to the speakers out of the motherboard.
  5. Acer Chromebook CB3-532-C47C Speaker Replacement, Speakers: Schritt 5, Bild 1 von 1
    • Pry the right speaker up with your hand to remove.
  6. Acer Chromebook CB3-532-C47C Speaker Replacement: Schritt 6, Bild 1 von 2 Acer Chromebook CB3-532-C47C Speaker Replacement: Schritt 6, Bild 2 von 2
    • Thread the speaker under the black ribbon towards the left to allow removal of the left speaker.
  7. Acer Chromebook CB3-532-C47C Speaker Replacement: Schritt 7, Bild 1 von 1
    • Pry up the left speaker to remove it.
    • Remove both speakers.
Abschluss
Sadie Brown
967 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 3-2, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G2
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 197
