Zum Hauptinhalt wechseln
Acer Chromebook CB3-532-C47C Touchpad Replacement
Was du brauchst
  1. Acer Chromebook CB3-532-C47C Touchpad Replacement, Back Panel: Schritt 1, Bild 1 von 2 Acer Chromebook CB3-532-C47C Touchpad Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Touchpad Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook CB3-532-C47C Touchpad Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Touchpad Replacement, Remove the battery cable: Schritt 3, Bild 1 von 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Touchpad Replacement, Battery: Schritt 4, Bild 1 von 2 Acer Chromebook CB3-532-C47C Touchpad Replacement, Battery: Schritt 4, Bild 2 von 2
    • Using the Phillips #1 screwdriver, remove the two black 5.5 mm screws securing the battery.
  5. Acer Chromebook CB3-532-C47C Touchpad Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery from the laptop.
  6. Acer Chromebook CB3-532-C47C Touchpad Replacement, Touchpad: Schritt 6, Bild 1 von 2 Acer Chromebook CB3-532-C47C Touchpad Replacement, Touchpad: Schritt 6, Bild 2 von 2
    • Flip up the retaining latch securing the touchpad cable to the motherboard.
  7. Acer Chromebook CB3-532-C47C Touchpad Replacement: Schritt 7, Bild 1 von 1
    • Pull the ribbon from the motherboard laterally off the touchpad.
  8. Acer Chromebook CB3-532-C47C Touchpad Replacement: Schritt 8, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove the three 3.2 mm screws holding the touchpad to the laptop.
  9. Acer Chromebook CB3-532-C47C Touchpad Replacement: Schritt 9, Bild 1 von 3 Acer Chromebook CB3-532-C47C Touchpad Replacement: Schritt 9, Bild 2 von 3 Acer Chromebook CB3-532-C47C Touchpad Replacement: Schritt 9, Bild 3 von 3
    • Carefully lift up on the keyboard ribbon cable and the insulating sheet immediately below it so the touchpad can clear them.
    • Lift the touchpad slightly from the top.
    • Pull the touchpad toward the motherboard as you continue to lift it, sliding it out from under the retaining fingers at the bottom.
  10. Acer Chromebook CB3-532-C47C Touchpad Replacement: Schritt 10, Bild 1 von 3 Acer Chromebook CB3-532-C47C Touchpad Replacement: Schritt 10, Bild 2 von 3 Acer Chromebook CB3-532-C47C Touchpad Replacement: Schritt 10, Bild 3 von 3
    • Remove the touchpad.
    • When reinstalling:
    • Make sure the touchpad goes underneath the two retaining fingers when reinstalling it.
    • The touchpad is correctly aligned when the guide pins next to the left and right screws are inserted in the holes.
Abschluss
Sadie Brown
967 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 3-2, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G2
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 290
