Zum Hauptinhalt wechseln
Acer Chromebook R11 C738T-C44Z Battery Replacement
Was du brauchst
  1. Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: Schritt 1, Bild 1 von 3 Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: Schritt 1, Bild 2 von 3 Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Battery Replacement, Battery: Schritt 2, Bild 1 von 2 Acer Chromebook R11 C738T-C44Z Battery Replacement, Battery: Schritt 2, Bild 2 von 2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Battery Replacement: Schritt 4, Bild 1 von 1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
Abschluss
To reassemble your device, follow step one and two in reverse order.
Gateway, Team 1-4, Saknee Fall 2021 Mitglied von Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 532
