Einleitung
If your Acer Chromebook Spin 15 CP315-1H-P1K8 back cover has scratches or is broken, this guide will help you to replace the back cover of the laptop. This guide will also help you to access the inner parts of the laptop. Please make sure to switch off the laptop before working on the back cover replacement.
This guide does not acquire any special skill. Get ready with a screwdriver and a iFixit opening tool when working through the guide.
Was du brauchst
Flip the computer over so that the back is facing up.
Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
