Was du brauchst
Follow steps from the following guide to open up the computer : Acer Nitro 5 AN515-53-55G9 Akku tauschen
Identify if power cord to motherboard is or was damaged. In my case it was damaged because previous repair person accidentally screw the tray back through the power cord as the power cord was a little loose and too close to the screw as shown in the picture.
Make sure the cable is composed of 3 red cables and 3 black cables, and the inlet is similar to the one in your laptop.
Look online and purchase - DC Power Jack Harness Cable Socket Plug Charging Port Replacement for Acer Nitro 5 AN515-53-55G9 - Acer C5PRH DC301010K00 DC IN Cable Power Jack Connector Charging Port.
Ein Kommentar
I wanted to know how to remove the power cord connector from motherboard, its locked in place
