Einleitung
If you have display assembly , Whether you've encountered a cracked screen, malfunctioning display, or other issues with your laptop or monitor, this step-by-step walkthrough will help you replace the display assembly and get your device back to optimal working condition. With detailed instructions and tips, we'll guide you through the process, ensuring a smooth and successful replacement of your display assembly.
Was du brauchst
Use a Torx T5 screwdriver to remove the eleven screws that secure the lower case.
Insert an opening pick in the seam between the lower case and chassis.
Slide the pick around the perimeter while prying until the lower case releases.
Remove the lower case.
Use a Phillips #1 screwdriver to remove the 5.5 mm screws securing the hinges.
Disconnect the display cable.
