Einleitung
Use this guide to replace the lower case on an Acer Swift X N20C12.
Was du brauchst
Use a Torx T5 screwdriver to remove the eleven screws that secure the lower case.
Insert an opening pick in the seam between the lower case and chassis.
Slide the pick around the perimeter while prying until the lower case releases.
Remove the lower case.
Fast fertig!
Abschluss
